Bad vibration around 60MPH
Old Jul 14, 2015 | 10:27 AM
Dolphinsnum1fan's Avatar
Default Bad vibration around 60MPH
I am having s really bad vibration when cruising around 60. I am new to owning Hondas. It's also pulling to the right has well. It's a 2002 AWD.
Old Jul 14, 2015 | 06:43 PM
lowlife9's Avatar
wheel bearing,bent rim,missing wheel weight, tires aren't round,bad wheel balance.
Old Jul 16, 2015 | 08:31 PM
Tires seperating
Old Jul 16, 2015 | 10:08 PM
lowlife9's Avatar
Originally Posted by bucwheat
Tires seperating
that's usually at low speeds under 20 mph.
Old Jul 17, 2015 | 07:09 PM
It does happen at higher speeds,had a seperated tire on the front of my dually a few years ago it pulled and vibrated but not at 60 mph ,your right.
Old Oct 29, 2022 | 09:42 PM
That-qualified-not-certified-mechan's Avatar
I'm having the same problem right now and can't go over 58mph without its shaking terribly bad but it's fine at 58 and under but anything over that it feels like it's gonna shake apart. I've had the tires balanced and rotate and it only does it on the passenger side. Now it's possible that it needs an alignment but it's never been aligned and it just started randomly one day and I can't seem to find what it is. Has anyone had this happen and they fix it?
Old Oct 29, 2022 | 10:25 PM
Switch the tires around. Does the vibration move? If so, you have a bad tire.
civichybridsue
Oct 4, 2014 08:54 AM
BADVET
Apr 13, 2010 06:45 AM
fastoldguy
Jan 12, 2009 10:07 PM
AndrewL
Sep 18, 2008 11:51 PM
mclebed
Sep 3, 2008 03:40 PM
