Catalytic converter clearance..?
Old 05-03-2020 | 07:42 PM
fang508's Avatar
Default Catalytic converter clearance..?
I bought a direct fit catalytic converter off of Ebay. Everything bolts up just fine but one corner of the engine side of the catalytic converter is touching the heat shield mounted on the tunnel above it. The new converter also did not come with any heatshields or even flanges so I could mount the ones I removed from the bad original converter. My only real concern is about heat transfer from the tunnel to the floorboards creating a possible carpet fire hazard.....think this will be an issue?
Old 05-21-2020 | 08:18 PM
Welcome to the forum. Yes the cat puts out a lot of heat hotter than a muffler. Must have a heat shield of some type or you will be smelling your insulation and carpet smoldering.
klepperguy
11-09-2013 11:53 AM
pergojr
08-21-2013 01:34 PM
beef
07-25-2011 11:37 AM
joed2222
04-14-2010 05:06 AM
george106
06-03-2009 09:38 PM
