Catalytic converter clearance..?
Old May 3, 2020 | 06:42 PM
fang508's Avatar
Default Catalytic converter clearance..?
I bought a direct fit catalytic converter off of Ebay. Everything bolts up just fine but one corner of the engine side of the catalytic converter is touching the heat shield mounted on the tunnel above it. The new converter also did not come with any heatshields or even flanges so I could mount the ones I removed from the bad original converter. My only real concern is about heat transfer from the tunnel to the floorboards creating a possible carpet fire hazard.....think this will be an issue?
Old May 21, 2020 | 07:18 PM
Welcome to the forum. Yes the cat puts out a lot of heat hotter than a muffler. Must have a heat shield of some type or you will be smelling your insulation and carpet smoldering.
klepperguy
Nov 9, 2013 10:53 AM
pergojr
Aug 21, 2013 12:34 PM
beef
Jul 25, 2011 10:37 AM
joed2222
Apr 14, 2010 04:06 AM
george106
Jun 3, 2009 08:38 PM
