Clock on nav unit keeps resetting (2011 CR-V EX 2.2 iDTEC)
Old Jan 3, 2022 | 08:50 AM
chewbob's Avatar
Default Clock on nav unit keeps resetting (2011 CR-V EX 2.2 iDTEC)
Hi.
I recently acquired my CR-V 2011 EX (has nav unit) 2.2 (UK) and the clock on the nav unit was working fine until a couple of days ago. It now resets the time to 01:00 every time the car is started.
I’ve checked settings, set it to automatically update etc but it seems to make no difference. I’ve checked relevant fuses but all seem to be in tact.
I'm confused because I was under the impression the time was retrieved via GPS on this model which does not seem to be happening now. GPS signal seems to be achieved just fine and the location is accurate. Any help would be appreciated.
Thanks.
Old Jan 3, 2022 | 09:01 AM
chewbob's Avatar
Apologies for double post but as luck would have it I saw a similar thread on another forum describing a similar issue. Seems to be a problem with the way the nav unit stores the date/time and it can’t handle the year 2022 and thus defaults to 01:00 every time the car is started.
Not sure there’s anything to be done about it other than shell out for a software update! (Which I absolutely will not be doing…)
Old Jan 3, 2022 | 05:40 PM
14Ridgeline's Avatar
Originally Posted by chewbob
Hi.
Thanks.
It's happening to all the Ridgelines with NAV also. Clocks and dates resetting to 2002 and time now updating. 2K22 software glitch it seems.
Old Jan 19, 2022 | 09:41 PM
ROC2010RTL's Avatar
A software up date won't solve the problem According to Honda techs, the problem will correct itself in August 2022. I kid you not. So far, no answers. Disconnecting and reconnecting the battery will not help either.
guthrie1
Jun 13, 2018 04:32 PM
madabouthonda1
Nov 25, 2015 08:47 PM
hyeinkali
Sep 13, 2012 10:28 AM
faithanne
Jan 21, 2009 03:55 AM
