CRV Oil capacity
Old May 5, 2018 | 12:48 PM
sdking's Avatar
Default CRV Oil capacity
Hello,
I am able to drain only about 3.5 quarts from my 2016 CRV. Adding just 3 quarts of oil makes the dip stick read full. Anyone has similar problem ?
I used jack to lift the passenger side of the car after oil stopped dripping from drain plug and couple of oz dripped. It seems to me that oil pan is holding some oil
Thanks
Old May 6, 2018 | 08:12 AM
Your CRV contains 4.4 quarts of oil for the 2.4L engine,you will never completely drain the crankcase on any car for example I have an Ford F 350 diesel truck that holds 18 quarts but only takes 13.5 on oil changes. Even when your vehicle is completely level you won't do better than that.
Old Apr 9, 2021 | 03:29 PM
Matthew11's Avatar
Hello, sdking. What engine do you have?
According to the specs at https://engineswork.com/oil-capacity...-capacity.html your 2016 CR-V might have 4.44 US Quarts or 4.23 US Quarts WITHOUT FILTER!
Probably you (most likely) you didn't drain all the oil.
Brett Nolan
Feb 1, 2020 06:50 PM
John000
Nov 11, 2019 10:21 PM
John000
Oct 14, 2019 02:55 AM
Robert Koziak
Feb 12, 2019 09:25 PM
thesarge
Dec 18, 2018 11:48 AM
