Front turn signal hyper flash
Old Feb 16, 2019 | 10:50 AM
BobCRV's Avatar
Default Front turn signal hyper flash
I installed LED Buld with hyper flash resistor in the rear turn signals. Works great no hyper flash. I installed Sirius LED with built in resistor 1157A in the front turn signal positions. II get hyper with the engine running. With engine off no hyper flash. Any suggestion?
Old Feb 22, 2019 | 01:18 AM
Lochinvar's Avatar
The malfunction detector that causes the signals to hyper flash when you have a burned out bulb might just be too sensitive for that model of LED bulb to work, especially if you already have them in the rear lights. Remember, these cars were designed to use regular light bulbs.
Do the signals work normally when you put incandescent bulbs back in?
Old Feb 24, 2019 | 06:00 PM
I have had issues with some of these LED bulbs causing hyper flash,others are fine,stay away from the cheap Chinese bulbs.
Mike Hartmann
May 19, 2018 07:44 PM
technotrevor
Feb 21, 2016 09:04 AM
Oct 20, 2014 04:50 AM
stellaj908
Dec 1, 2013 10:49 AM
RedCivic01
Apr 21, 2013 01:28 PM
