Led turn signals question
Old Jan 19, 2013 | 03:29 AM
stellaj908's Avatar
Default Led turn signals question
Some websites recommend a pair of load resistors for LED turn signal lights. Will it work or burn out faster if I don't get load resistors?
Old Jan 22, 2013 | 07:23 PM
lowlife9's Avatar
you don't need load resistors you just need to upgrade your turn signal flasher relay under the hood in the fuse box.you can find them at pepboys or any parts stores for 12 bucks usually under the brand name TRIDON. your looking for a heavy duty or led flasher like this tridon ep34 http://www.amazon.com/Tridon-EP34-Flasher/dp/B00064LQKS the load resistors and relay flasher accomplish the same thing they prevent your led bulbs from hyper flashing. since leds use so little power like 1 watt your car thinks your bulbs are burnt out making your turn signals flash like a stobe light to warn you the bulbs out.
Old Dec 1, 2013 | 10:49 AM
PimpMyLights's Avatar
Donkeydawn11
Jan 27, 2010 03:35 AM
HMH
Jan 27, 2010 02:38 AM
vilfredo
Mar 7, 2009 11:00 AM
fitty88
Apr 5, 2007 09:27 PM
jack_spicer
Aug 18, 2006 12:46 PM
