Help? Crv blows white smoke but no overheat or loss of power
Old Mar 5, 2020 | 09:08 PM
Jena0227's Avatar
Default Help? Crv blows white smoke but no overheat or loss of power
Just recently bought a 99 crv but has white smoke blowing through tailpipe. No oil or leak in tail pipe and no overheating or loss of coolant. Under oil cap is still good and Pcv valve still rattles. Does burn some oil. Any advice to check? Kind of at a loss on figuring this one out..
Old Mar 5, 2020 | 10:49 PM
you can check the spark plugs to see which cylinder the oil is being burned, also do a compression check to see if you have a weak cylinder, oil can also be seeping through your valve guide. oil rings could be worn and not keeping the oil off the cylinder walls in the crank case.
Old Mar 5, 2020 | 10:51 PM
Jena0227's Avatar
Spark plugs all good but will do a compression check. Thanks.
Steve Bowles
Aug 8, 2017 06:16 PM
desione08
Sep 20, 2009 11:13 AM
lasantha
Sep 1, 2009 07:26 PM
dahuckman15
May 30, 2008 03:25 AM
i4
May 29, 2007 04:40 PM
