Issues Faced in a brand new Honda CRV 2019
Old Mar 17, 2020 | 04:20 PM
Bradleyp's Avatar
Default Issues Faced in a brand new Honda CRV 2019
Dear All,
I need your support on some issues which I'm currently facing since day one of my purchase. I live in the Middle East and have purchased a brand new Honda CRV 2019.
1) The vehicle center top dome light works but it is actually supposed to get dim gradually and automatically go off once I get inside and switch on the engine. However, the lights only get illuminated when I open the door and remain continually on and I dunno why this problem exists. I tried changing the setting in the three stages available, however no use.
2) When I turn on the ignition I start playing the audio (MP3) from my USB the track plays properly however after approx 2 minutes the track display screen info becomes blank and stops playing that particular track. I initially thought that there was an issue with the USB device so I purchased a brand new one to confirm but the same issue exists. After I manually start/resume playing the track again it always works fine. This same issue happens even if the track continues from my last playing time after I return to start my car. I have observed that this track playing from the USB issue is repetitive after turning off and on the infotainment screen. (Attached photos 2 & 3)
3) Is there any way to update the Firmware and software revision of the built-in infotainment system.
4) Is there any way in which we can view the photos of the albums on one single screen by swiping across using the built-in infotainment system.
5) I noticed that the setting to view/check the oil level isn't available on the instrument panel.
6) After I turn off and turn on the engine I observed a shutter kind of noise heard whenever pilot in an aircraft activates its breaks and releases the parking brakes. This similar noise is also heard whenever I engage and disengage the parking brakes.
7) Thrice this week, I have noticed a flaw in the infotainment system after starting up the engine and driving. The infotainment system gets hanged up initially and displays a black screen. Even the lane watch and reverse camera image doesn't appear, in fact, nothing shows up. However, during the second instance, I found that the system started responding but was painfully slow to respond. (Attached photo 1)
Infotainment Screen Hanged
Lane Watch Camera Hanged
Audio System Fails to Load up on screen
Old Mar 24, 2020 | 07:41 PM
Welcome to the forum. Your car is under factory warranty. If you try to fix anything yourself. You will void your warranty. Highly recommend that you take your new vehicle to the dealership and advise them of what is failing. So it will be on record.
Old Jul 7, 2021 | 07:45 PM
drol343's Avatar
I and many others have issue with the Screen failing and or act strange.
I had a Software Update about a month ago and it seemed to fix it.
Verena Lang Tetley
Aug 5, 2020 10:39 PM
testpilot
Apr 8, 2019 09:11 PM
dl41001
Nov 30, 2018 06:15 PM
Rookie50
Nov 24, 2018 10:59 AM
Crystal Benson
Mar 28, 2018 07:52 PM
