lost compression #
Old May 14, 2021 | 04:48 PM
flint9's Avatar
Default lost compression #
my daughters 11 crv started running rough.check engine light flashed. had towed to my repair shop. lost compression # 3 clyinder. valve cover was pulled and checked, no visable rocker valve issue,s. this car has had a oil burning issue since buying used. miles now is 155xxx.any help folks?
Old May 15, 2021 | 04:51 AM
welcome to the forum. during the compression check where was the air leaking out of, if intake, top overhaul, if exhaust top overhaul if crankcase piston rings worn. if top overhaual find out if you can find a good used low milage engine for about 500-700.00 with removal and install for 500-800.00. just a note, when the head is overhauled, it does put more pressure on the pistons due to head being tight w/no leaks.
Old May 15, 2021 | 11:47 AM
flint9's Avatar
my mech did not say where it was blowing by. i am wondering about cost for a top end rebuild, and if the rings are bad. dont if that can be done with out pulling engine etc. and cost going to high.
Old May 15, 2021 | 01:18 PM
First got to figure out where the leak is.
Is it in the head gasket? I
Is it the valves?
Is it the rings or piston?
Each one has a different cost associated with it.
Have you done a leak down test?
Take out spark plugs and hook up a hose to a cylinder
Turn engine over to close the vales on the cylinder
Then pressurize and check to see how fast it is leaking
That should tell you whether it is a valve or ring and piston?
Then call and ask for options along with cost for each option
Good luck
Old May 15, 2021 | 07:07 PM
flint9's Avatar
yes a good diagnostic will be needed.. car is really not drivable so it will have to be towed (costly)so i am trying to get as much info on my options as possible everybodys help is appreciated. can they replace rings without removing engine? how much labor/hours?
Old May 15, 2021 | 07:29 PM
If the rings need replacing then the mechanic will usually ask if you want to get a used engine put in
But, cost all depends on where you take it.
Willcrvowner
Dec 18, 2018 10:59 AM
calirican76
Mar 20, 2014 09:21 PM
commpilot5
Jan 27, 2010 02:23 AM
Bob SR
Sep 16, 2009 12:21 PM
H22ACCORD
Nov 6, 2008 06:34 AM
