Mystery Tube
Old Dec 18, 2018 | 04:15 PM
Les Moore's Avatar
Default Mystery Tube
Howdy, I just cleaned out the throttle body on my 2002 CR-V EX, and of course there is a pipe on the the intake manifold where the TB mounts that I have no tube to connect to. Could anyone tell me what tube attaches there and how many things I will have to remove again to find it? You can see the pipe I'm talking about in the attached pic. Thanks very much and the best of the season.
Old Dec 21, 2018 | 12:35 PM
There should be a hose that goes to the evaporation emission purge valve.
The valve is a normally closed valve that should reside in the engine bay.
Old Dec 26, 2018 | 12:02 PM
Les Moore's Avatar
Thanks. The EVAP purge valve solenoid is located on top of the throttle body, and that's all set. Is the EVAP purge valve a seperate part, located on the cannister?
Thanks again, very much.
Old Dec 27, 2018 | 03:15 PM
Lochinvar's Avatar
Usually, the solenoid and valve are one component. It should connect to that tube, and the EVAP canister directly.
peasthope
Apr 12, 2018 09:12 AM
Bob2000
Apr 24, 2016 09:05 PM
Joey86
Apr 12, 2013 08:10 PM
blueboy
Nov 15, 2011 01:55 PM
commpilot5
Jan 27, 2010 02:23 AM
