Rd5 Crv transmission issues
Old Feb 22, 2022 | 12:56 AM
King's Avatar
Default Rd5 Crv transmission issues
I have a rd5 Crv 4spd auto transmission.. I've noticed that whenever I select reverse gear the vehicle is hesitant to move plus the gear seems to be slipping...... Can this be repaired or do I need to buy a new transmission? Can a k20 5spd or a k24 5spd auto transmission bolt on and work properly with the Crv k20a4???
Old Feb 22, 2022 | 11:03 AM
welcome to the forum. might try changing the trans fluid with honda only trans fluid, and see what the out come is. if same try to get a stock same good used transmission from a notable salvage yard.
Old Feb 22, 2022 | 04:10 PM
Whoa on getting another transmission. There's a few things that can cause that. It could be a leaky servo piston seal which is an easy repair compared to replacing the trans. Do a fluid swap and see what you get.
Old Feb 22, 2022 | 05:11 PM
King's Avatar
Thanks.....
Yes I've recently changed the transmissions fluid.....
Old Feb 22, 2022 | 05:13 PM
King's Avatar
I thought about changing all the seals....
Old Feb 22, 2022 | 06:32 PM
If you are going to tear it down and do that I recommend you put a master kit in it.
BradW
Sep 14, 2021 08:49 PM
shebet
Nov 11, 2017 11:50 AM
Alex Zuidema
Jun 21, 2017 07:25 PM
Wolf31
Oct 6, 2012 10:14 AM
mcqueen
Jan 22, 2008 04:51 AM
