Sunroof won't slide back, but still tilts
Old Feb 27, 2018 | 11:05 AM
lurky's Avatar
Default Sunroof won't slide back, but still tilts
Hello,
I have a 2010 CRV with a sunroof that tilts up and the slides back. When I press the button, it will still tilt, but it no longer slides back.
Is this a common problem, is there a solution I could implement myself or does it require a mechanic?
It would guess that there are separate motors for tilt and slide and one burned out?
Thanks
Old Mar 1, 2018 | 09:29 AM
My suggestion would be to have someone operate the roof while you try to see if maybe a lever or connection has come loose. I had one years ago that had an electrical issue,I took it to a windshield shop and the fixed it,check with your local glass co.
POE
Mar 29, 2018 09:45 AM
Nitwit
Jan 30, 2018 04:34 PM
proud-owner-of-zippy
Mar 31, 2011 07:27 AM
gixxerdude1979
Feb 20, 2008 07:42 PM
gixxerdude1979
Dec 17, 2007 11:35 AM
