Timing marks don't align
Old 10-27-2023 | 06:37 PM
wwdwgs's Avatar
Default Timing marks don't align
Hello, everyone.
I'm in a process of replacing head gaskets.
when I was disassembling parts, I couldn't find timing marks (blue or yellow links). The engine was at TDC, marks on cam shaft sprockets (including notches) and crank pulley (harmonic balancer) were aligned. I didn't know and didn't check of intake cam sprocket timing lined up with an arrow on first cam "bridge".
Since I didn't see those blue or yellow links, I marked corresponding links with white out.
Now is the time to install the timing chain... But.. I discovered those colored links, mine are yellow (brass). The reason I didn't see them is that they were "advanced" and were near a fixed guide/rail.
So.. Today I installed the timing chain - intake cam sprockets lined up with "bridge" arrow, yellow links over the timing mark, exhaust cam sprocket aligned to yellow links. But.. the notches on these sprockets did not align... Also a single yellow link at the bottom by crank sprocket didn't align either - it's past timing dot by one link. Also the yellow links of a short chain (at crank) don't align wit timing mark either.
Before disassembly, cam sprocket notches (so called 3 and 9 o'clock positions on exhaust and intake cams resp.) aligned....
See the pictures below.
existing timing marks before disassembly:
Below are the pictures I took now (with timing chain yellow links aligned with timing marks):
and picture of cam shaft:
All these pictures show loose timing chain - without adjustable rail/guide and tensioner.
I also reinstalled timing chain with old (white-out) marks - same thing - misalignment.
I am puzzled. The valves are all closed and not adjusted yet. I really don't understand why timing belt was:
1 - installed without yellow links aligned
2 - why nothing aligns now...
BTW, the engine was never worked on and no one worked on timing chain or valves. This is a first job that requires some engine disassembly.
obviously, I need you input and advice.
Old 10-27-2023 | 08:53 PM
Those links are used for installing only. Once the engine is run those links will only find those positions again maybe 1 in 200 revolutions or more.
Old 07-21-2024 | 04:40 PM
Silvercrv's Avatar
If all timing marks are lined up, pins in the holes on the other end of the cams, and the colored links won’t fall into place, then what?
Old 07-21-2024 | 07:39 PM
If the cams and the crank are on their marks the links on the chain mean nothing.
HondaDude48
11-22-2021 09:44 AM
forevermemorable
10-05-2020 09:38 PM
jeffsch
01-12-2019 01:45 PM
forevermemorable
09-20-2013 12:36 PM
slloth
02-04-2011 09:08 AM
