Voltage drop to starter
Old Aug 18, 2025 | 09:56 AM
GreenvilleHonda's Avatar
Default Voltage drop to starter
Asking for a friend: I am an experienced mechanic with limited Honda knowledge. Please help. My friend has a 2016 HRV that has an intermittent problem (the worst kind). The battery has consistent 12.64 volts, alternator 14.39, the terminals are clean, no issues here. The voltage at the starter is 8,8 volts but there is no problem cranking and starting the car. The problem is some times when stopped the engine will shut off or when driving the engine will run rough. I did not run the tests but saw the results on a print out from a local shop that claimed the starter is defective. The voltage drop from the battery to the starter is what I am trying to diagnose. Has anyone ever seen this problem? Did you find the source of the problem? Your help is appreciated.
I will add to this because someone posted a reply and then evidently removed it questioning why I posted in this Forum and not the HRV Forum. The answer is that I do not see a Forum for the HRV Honda. If there is one, please provide a link. Thanks!
Last edited by GreenvilleHonda; Aug 18, 2025 at 02:02 PM. Reason: Additional comment required
Old Aug 18, 2025 | 03:54 PM
Just Ducky's Avatar
Old Aug 18, 2025 | 04:05 PM
Would I be correct in assuming that you suggest I post in the section for "Other Honda Cars and Trucks"?
Old Aug 18, 2025 | 08:09 PM
Do we have a new starter?
Old Aug 19, 2025 | 06:59 AM
Just Ducky's Avatar
Nope, just answering your secondary question. Post wherever you want.
JR66
Jul 5, 2020 11:24 PM
watertoys
Dec 12, 2018 10:33 AM
Break Room Vendors
Nov 23, 2018 11:41 PM
forevermemorable
Oct 8, 2013 08:57 PM
Abagumyan
Jun 2, 2010 02:45 AM
