What's the light above the rear window called?
Old Jun 12, 2019 | 08:44 AM
Finch Platte's Avatar
Member
Default What's the light above the rear window called?
I had the strip painted above my rear window (https://hondaforum.com/forum/cr-v-fo...painted-13581/), now the white lens for the light sticks out like a sore thumb. I'd like to replace it with a darker lens, but don't know what the part is called in able to search for it.
Also, has anyone had success "painting" something like this? A guy at work says to get black spray paint and just haze the lens, but I'd rather buy a pre-darkened one.
Old Jun 12, 2019 | 10:35 AM
part is listed under tail gate. called light assy, high mount stop.
Old Jun 13, 2019 | 07:53 PM
If you are talking about the third brake light,you can buy a spray tint. Remove the lens Clean it with alcohol and spray a light coat first wait 30 minutes and add another coat,that should do it,if you think it's not dark enough spray another,if you mess up lacquer thinner will clean it off,good luck.
Old Jun 16, 2019 | 01:08 AM
Member
Yes! Third brake light, thank you. Didn't know there was a spray tint, I'll check that out, thanks.
Edit: I found this: https://www.zoro.com/rust-oleum-lens...OT_TYPE=SIMPLE
Old Jun 17, 2019 | 09:37 PM
https://www.youtube.com/watch?v=yb-BfoYwMqY
Use light coats to get the desired level of darkness and avoid runs.good luck.
skjlprince
Feb 13, 2020 12:15 PM
B0B
Oct 11, 2017 01:54 PM
Mar 25, 2015 09:06 AM
rookie60
Dec 9, 2007 02:45 PM
phyl26
Mar 18, 2007 07:55 PM
