Wiper issues
Old Jun 25, 2022 | 04:05 PM
Davethetoolman's Avatar
Default Wiper issues
I have a 2013 CR V. The wipers only work on temporary(push lever up) or on high. Also, washer works but no wiper. Odd symptom is when you put car in reverse, rear wiper activates. New motor and switch. What the heck?
Old Jun 26, 2022 | 12:08 AM
If the wiper switch is turned on then putting the gear selector in reverse does turn on the rear wiper. That is the direction you are going.
Would need to test the wiper switch.
Old Jun 26, 2022 | 10:38 AM
Low speed and intermittent do not work? The rheostat is likely open.
Old Jun 26, 2022 | 01:05 PM
Output of wiper switch goes to the MICU (multiplex integrated control unit).
Seems likely the MICU is not functioning proper if you have already replaced the motor and switch.
Would need to check continuity of the wiring from switch to MICU.
Also check all fuses.
Best is to get a schematic of the wiper circuit.
Richiesemtner
Apr 5, 2022 09:29 AM
Lochinvar
Dec 18, 2018 10:42 AM
Jan 28, 2016 07:16 AM
civiclover
Jul 20, 2015 10:32 PM
Megafast13
Apr 8, 2009 12:11 PM
