2001 honda accord 4cy VTEC 4000 rpm cuts out
Old Oct 28, 2021 | 11:27 PM
Vizzle's Avatar
Default 2001 honda accord 4cy VTEC 4000 rpm cuts out
My timing was replaced by my neighbor and he swears it's done correctly but it won't go past 4000 rpm. It's Either not timed right or something else. He swears he timed it right. If the timing is off would it effect the VTEC solenoid? Will the timing effect vtech?
Old Oct 29, 2021 | 10:11 PM
if the only thing that was changed was the timing belt, it is possible the timing is one tooth off. Put #1 piston on compression TDC and check the alignment points for the cam and crank should not be hard to do. if you can view a few utube videos of timing belt and alighnment, .
Old Oct 30, 2021 | 01:17 PM
Vizzle's Avatar
he also put a header on the exhaust could that be the problem
Old Oct 30, 2021 | 09:39 PM
header on the exhaust only makes for a better exhaust gas flow.. might also check your cat.to see if its is plugged. .
snotsmear
May 16, 2017 01:25 PM
driveability
Jun 30, 2013 07:19 PM
ailwyn
Jan 8, 2009 05:54 AM
b16civic93
Sep 13, 2008 07:57 AM
