clock light
Old Dec 1, 2008 | 01:19 PM
tferstl's Avatar
Default clock light
Does anyone know how/why the 2001 Accord clock does/does not have a light?
Old Dec 5, 2008 | 07:22 AM
Default RE: clock light
01 accord has a light in the clock. small bulb in the back. found this in yahoo by honda guy. you can remove the clock by pulling on the rectangle that surrounds the clock with equal pressure on all sides. The clock should just pop out. you'll see the back of the bulb as a round plastic screw about 1/8th inch in diameter and about 1/16" high. It should be a cavity on the back of the clock on the passenger side of the clock when looking at the clock from the front. You can disconnect the clock connectors if ou want but its not necessary to remove the bulb. Simply use a small screwdriver to turn the bulb 1/4 turn (ccw) and it will come out. You will probably have to buy the bulb at a Honda Dealer. If you don't want to take the clock out, ask the parts guy for a bulb and I would venture to guess that the dealer will have someone put it in for you at no charge because its that easy to do. Per Honda Guy.
Sue
May 9, 2016 06:35 AM
acmech52
Dec 12, 2009 03:20 AM
Domaeromi
Dec 11, 2009 06:36 AM
jrecufan
Mar 28, 2007 11:26 PM
hd3
Nov 15, 2006 12:56 AM
