Grounding question
Old Jul 25, 2023 | 11:26 PM
First Last's Avatar
Default Grounding question
Not sure if this is the right place for this question. I'll be setting up my ham radio for transmitting (100 watts) and receiving in the car and need to provide it with a good ground system. Can anyone suggest where are the good points to run a ground wire to and how many? I've read different opinions ranging from 1 to 30. Also what is the recommended wire gauge (or braid)?
Many thanks
Old Aug 12, 2023 | 04:24 AM
Bubbalou88's Avatar
At the Battery
Old Aug 12, 2023 | 07:46 PM
Use whatever is required for your unit and ground it to body or frame.
Kind of strange for a ham operator not to know this.
Old Aug 12, 2023 | 07:57 PM
100W is the output of the unit. You need to know how many watts it uses. Highly unlikely that it uses the same.
Old Aug 12, 2023 | 08:15 PM
Bubbalou88's Avatar
When I installed 2 way Radio, lights, siren on Police, Fire and Ambulance we typically tied to the Vehicle Ground bolt normally behind the passenger kick panel or directly to the battery depending on availability and needs. The amperage the circuit consumed dictated wire size (varied between 10 awg-6 awg typically) and properly fused.
Old Aug 27, 2023 | 06:06 PM
Bubbalou88's Avatar
It should pull between 8.5-10 amps of current depending on the Radio’s efficiency. Even though #14 awg wire would do it I personally would use 12 awg with no larger than a 20 amp fuse but no smaller than 14awg wire and a 15 amp fuse at the power source.
bigbird74
Oct 21, 2019 03:20 PM
ejradig
Feb 18, 2018 07:18 AM
Fordf250
Oct 22, 2015 05:02 PM
gmech699
May 11, 2009 10:56 AM
shark254
Oct 10, 2006 10:59 PM
