Honda Engine Series...differences?
Old 04-05-2010 | 03:18 PM
gadget's Avatar
Default Honda Engine Series...differences?
I'm a noob to this whole culture, so forgive me if this is an amazingly remedial question. We all had to start somewhere, I guess.
What are the differences between the different Honda engine series?
I want to know, basically, every difference between the different Honda engines. So any info you have on the B, D, H, J, and K (and any others I might be missing) would be amazing.
Old 04-05-2010 | 07:42 PM
Civic_Whiz-kid's Avatar
B series engines are Dual overhead cames (DOHC)with some coming v-tec and non vtec these go all the way up to 2.0 liters
D series are single overhead cam (SOHC) and dual with some coming v-tec and non vtec theses go only to 1.7 liters
H series was the high preformance engine inthe 90's and early 2000 models .. but was replaced by the F series
J series is the second generation of Hondas V6 engines .. this engine replaced all C series engines in the late 90's this engine is amazing it converts itself from V6 to a straight 3 cylinder when not under stress and 4 cylinders when in above normal conditions ( iVtec) .. gas saver ..but super fast
K series is my favorite and i think you can make Extremly fast of 4 cylinders. this is a newer model engine .Vtec DOHC engine but the cam uses roller rockers to reduce friction. this engine take componets from the faviorite B series and H series and combine them into a perfect machine.
if you need anything else i got you
Old 04-06-2010 | 02:13 AM
gadget's Avatar
So what about weight differences. which one is lightest? Heaviest? Let me also explain why I'm asking. I'm going to try to build a car that is not a Honda or Acura with a Honda engine in it. And the car I am using to do this is super heavy. So I am trying to balance the best engine for speed and power with the lightest engine (and light everything else) to reduce that weight.
Nic Graham
08-11-2014 04:19 AM
rpsperformance
10-06-2009 01:39 PM
kwlakes
09-17-2009 10:30 AM
kayslay
03-29-2009 01:26 AM
penelopepitstop
11-16-2008 05:20 AM
