01 Civic Clutch Nearly at the Floor
Old 06-19-2014 | 01:54 PM
PCollen's Avatar
Default 01 Civic Clutch Nearly at the Floor
Over the past month, I've noticed that I have to depress my clutch nearly 100% to the floor. It returns 100%, but has about 95% downward travel before it activates . Fluid level looks OK, but would bleeding/replacing the fluid or simply adjusting the clutch travel help, or is this just a sign of extensive wear ?
Old 07-05-2014 | 01:43 PM
bleeding may help, also depends on how much you ride the clutch, it may be worn.
Old 07-08-2014 | 09:32 PM
PCollen's Avatar
Slave cylinder was leaking. I replaced both clutch master and slave cylinders. First new master cylinder from Advance Discount Auto was defective, which caused much confusion.
wsuhonda
01-22-2009 09:07 PM
wsuhonda
01-22-2009 09:03 PM
gtavalanche
12-08-2008 05:07 AM
vitovonantwon
06-30-2008 08:36 AM
dgresham2134
04-18-2008 01:12 AM
