01 Civic Clutch Nearly at the Floor
Old Jun 19, 2014 | 12:54 PM
PCollen's Avatar
Default 01 Civic Clutch Nearly at the Floor
Over the past month, I've noticed that I have to depress my clutch nearly 100% to the floor. It returns 100%, but has about 95% downward travel before it activates . Fluid level looks OK, but would bleeding/replacing the fluid or simply adjusting the clutch travel help, or is this just a sign of extensive wear ?
Old Jul 5, 2014 | 12:43 PM
bleeding may help, also depends on how much you ride the clutch, it may be worn.
Old Jul 8, 2014 | 08:32 PM
PCollen's Avatar
Slave cylinder was leaking. I replaced both clutch master and slave cylinders. First new master cylinder from Advance Discount Auto was defective, which caused much confusion.
wsuhonda
Jan 22, 2009 08:07 PM
wsuhonda
Jan 22, 2009 08:03 PM
gtavalanche
Dec 8, 2008 04:07 AM
vitovonantwon
Jun 30, 2008 07:36 AM
dgresham2134
Apr 18, 2008 12:12 AM
