1990 honda accord wont start when cold
Old Jun 11, 2010 | 11:12 AM
santiago's Avatar
Default 1990 honda accord wont start when cold
hi i have a 1990 honda accord and every morning that i go to turn it on it dont want to start i have to give it gas just to keep it on then when i let the gas go it turns off
Old Jun 18, 2010 | 03:03 AM
ck fuel pump pressure, are your spark plugs and wires good, coil/ignitor, distributor cap.
Old Jul 5, 2010 | 07:30 PM
santiago's Avatar
yeahijustreplacedallofthose
Old Jul 5, 2010 | 10:14 PM
have you checked your idle cut off and throttle position sensor.
Old Jul 8, 2010 | 08:39 PM
RiceCanRacing's Avatar
it could be a bad ignition coil also, when they start to go the car will tend to every once in awhile not want to idle. You could also be getting water in your gas (condensation) causing a rough idle and starving the engine for fuel. Check your injectors they could be dirty. Check the fuel lines and fuel filters they could have dirt in them. Also check your idle position sensor inside your throttle body it could have dirt on it causing unsmooth idle and possibly preventing the engine to stay at constant idle.
best way to fix some of those problems above is to get one of the following:
-Fuel injector cleaner
-Sea Foam (I recommended it for gas, oil, and also inside throttle body)
-Fuel Stabil
-104 Octane boost(I Recommend Lucas additive products containing STP)
-Marvel Mystery oil
-sensor cleaner (not available everywhere)
BCBoy
Jan 11, 2015 06:44 PM
tdow3
Oct 10, 2012 04:46 AM
m25m24
Dec 6, 2009 06:16 PM
soonerorlater627
Nov 17, 2008 06:45 PM
67l60
Apr 15, 2007 08:42 AM
