1991 CRX won't start when it rains?
Old 03-16-2007 | 09:00 PM
crelliott's Avatar
Default 1991 CRX won't start when it rains?
I have a 1991 CRX, and for some reason it won't start when it rains, and possibly due to drop in temperature. It doesn't sound like anything is wrong when I attempt to start, it just doesn't turn over. Sometimes, if I catch it before it has rained too much, it will start after several long attempts and with the gas pedal slammed. It kicks and spurts a few seconds, but then runs fine. I verified there is spark, but I'm not really sure where to go from there. I've even attempted starting spray to no avail. If anyone can help me I'd really appreciate it. Thanks.
Old 03-19-2007 | 02:18 AM
hondafied's Avatar
Default RE: 1991 CRX won't start when it rains?
Try draining and refilling your tank with new fuel. Your fuel may have water in it and when the humidity is really high durring rain it may not be able to fire
Old 03-29-2007 | 03:28 PM
Aloha crelliot: welcome to the forum...Check to see that your distributor is dry, make sure your spark plug wires are not too old and jumping to ground, ( will see a fine white/gray powder between the lines or spark jump at night ) Also a cracked distributor cap my cause hard start when raining or damp days
Old 04-04-2007 | 06:46 PM
joed2222's Avatar
I've had issues with the main relay on my '92 Accord. It would start when the outside temperature was high or very humid. When I replaced the main relay an the problem went away. I would also look at plug, wires, cap and rotor (shotgun approach). We replaced the main relay in my son's '93 Acura Legend and his starting problems went away too.
Chris Skoglun
06-27-2016 07:46 PM
samk
02-08-2013 11:31 AM
rebelagent
01-21-2010 04:41 PM
tdmansfield
09-11-2009 03:39 AM
slayer08
08-19-2009 12:06 PM
