1996 honda civic cx not starting like usual
Old Aug 27, 2012 | 09:03 AM
andrewporter's Avatar
Default 1996 honda civic cx not starting like usual
always the car starts , fires first time..,.now it only starts on 2nd turn of the ingition key! takes a few minutes of driving , then all smooth...feels like cylinders not all firing nicely till then...trouble light came on with the following errors:
p0420 p0301 p0302 p0304 p1300 ..all saying something about cylinder 1 2 4 misfire detected fuel and air metering ignition system mis fire....what can I do?? what needs cleaning or replacing??? thanks for any tips! motor at 370,000 kms runs well once going....
Old Aug 27, 2012 | 01:19 PM
lowlife9's Avatar
sounds like you have low fuel pressure change the fuel pump and filter and run some fuel system cleaner to clean the injectors.
Old Aug 27, 2012 | 05:42 PM
Default honda 1996 cx not starting on first attempt thanks
thanks I will look into getting a pumpo and see if it is this I'll let you know the progress..thankyou very much
andrewporter
Aug 30, 2012 11:01 AM
AcuraPartisan
Nov 23, 2010 03:52 PM
AcuraPartisan
Nov 23, 2010 03:51 PM
HondaChyck09
Dec 24, 2009 05:12 PM
Razorbacksfan88
Jan 27, 2007 03:55 AM
