1998 Acura Cl 2.3l Not hitting Vtec and issue with turn signals
Old Jan 13, 2019 | 07:37 PM
Ryan Hendricks's Avatar
Default 1998 Acura Cl 2.3l Not hitting Vtec and issue with turn signals
My buddy has a 1998 Acura Cl 2.3l that won't hit vtec it will hit act as if it hits redline when it gets to the appropriate rev range of vtec im thinking it might be oil pressure sender or something of that sort because he says it will flash the low light and when he checks the dipstick its completely full of oil. Could the fact the transmission is starting to be any factor?
And on another note his turn signals don't work at all although the hazzards work perfectly and the high beams still do work, could it still be the turn signal stock although the high beams still work? Tried messing with fuses but kind've got lost because I feel like his car is missing a couple. Could anybody post pictures of there fuse box's under the hood and in the interior(Can't find any good quality diagrams or pictures online)? So we can make sure we aren't missing any fuses.
Also the car has been hit on the right side in the fender
Last edited by Ryan Hendricks; Jan 13, 2019 at 07:40 PM. Reason: add some more details with the problem
Old Jan 14, 2019 | 12:52 AM
welcome to the forum. yes check the oil pressure switch to the vtec. have you checked the flasher unit for the blinker system. emergency and blinker usually have separate flasher.
Old Jan 14, 2019 | 07:47 PM
Thank You for the welcome and the response! I'll go check out oil pressure switch and the flasher unit
y2yang
Mar 5, 2019 11:53 PM
technotrevor
Feb 21, 2016 09:04 AM
denver
May 20, 2010 02:35 AM
civhatch91
May 27, 2009 12:40 AM
neonstryde
Dec 9, 2007 05:28 PM
