2000 Accord Won't idle, gas smell in cabin
Old Apr 18, 2008 | 02:56 AM
jpmack's Avatar
Default 2000 Accord Won't idle, gas smell in cabin
i've got a 2000 Accord 2.3l Vtec, Started smelling like gas in cabin, then 4 days later won't stay started, it will turn over but won't stay on. If I give it gas the engine will run but thats it. I replaced the fuel pressure regulator, but no change. Is there a fuel filter in my honda? I can't find record of it in my Haynes manual or Owner's manual. Do I need new injectors of new spark plugs? Need help and any suggestions!!!!
Old Apr 18, 2008 | 03:49 AM
Default RE: 2000 Accord Won't idle, gas smell in cabin
Welcome to the forum jpmack: according to the parts diagram on majestichonda.com I noticed the filter in the tank. Usually these are never changed. Also would a tune up on the accord help? like you mentioned plugs, wires, or dirty injectors.
Old Apr 18, 2008 | 07:31 AM
jpmack's Avatar
would any of these account for the smell of gas inside the car?
Old Apr 19, 2008 | 03:42 AM
If your engine is not burning up all the fuel properly, it usually comes back into the cab during deceleration with the window open. If you smell fuel while driving in a fwd direction, it may be exhaust fumes coming into the cab thru the firewall, or thru a hood leaking rear upper seal, this allows the fumes to come thru the lower front of the windshield vent area. ( about where thewiper blades are)
Old Apr 19, 2008 | 04:23 AM
jpmack's Avatar
thanks so far for your help....Today I will try a tune-up.....if that doesn't help,I guess I will take itin to get worked on....thanks again....glad to be a part of the forum
Old Apr 22, 2008 | 08:16 PM
forgot to mention, have you noticed if your fuel use has increased or poor milage, also any fuel dripping on the ground or fuel stains on any fuel hoses?
Marc
May 21, 2012 04:18 PM
Nguyener
Mar 26, 2011 09:03 PM
djm0836
Sep 13, 2009 09:17 PM
James
May 24, 2009 10:59 PM
lanetracey
Oct 28, 2006 08:34 AM
