2001 Civic head gasket
Old Nov 28, 2009 | 09:30 AM
jmurphnd's Avatar
Default 2001 Civic head gasket
Mechanic told my wife her 2001 Civic was in need of a new head gasket. Not being mechanically inclined I did a little research and it doesn't look like a very time consuming or expensive job. (Pull spark plug boots,remove bolts, remove cover and gasket, clean surfaces, replace gaskets, bolt cover, replace boots. can anyone tell me what such a job should cost. Don't want to get "taken over the hill" Thank you in advance.
Old Nov 28, 2009 | 09:38 AM
repair shop approx 750.00 dealer a bit higher due to labor this incl timing belt,water pump, anti-freeze, oil and filter, headgasket, crank and cam seals. (EST) If you get yourself a shop service manual, it will help you to do the job yourself.
Old Nov 28, 2009 | 02:38 PM
jmurphnd's Avatar
Default Head gasket
I'm inquiring about the head gasket. Not the timing belt, water pump. etc.
friggeth
Feb 14, 2014 09:23 PM
Bikeman982
Mar 4, 2010 08:56 PM
89hondacrx
Dec 23, 2009 07:22 PM
lofg0030
Aug 15, 2009 07:28 AM
mexxem2
Mar 25, 2008 10:45 AM
