2001 civic lx ECU/Link Erros problem.
Old Feb 15, 2012 | 07:32 PM
Oscar Ponce's Avatar
Unhappy 2001 civic lx ECU/Link Erros problem.
my 2001 civic has the check engine light on. I tried using a scanner to check the codes to see what the problem was. Every scanner i used said link error. My mechanic said it could be the ECU that went bad. I bought a new ECU and made sure the numbers matched the old one and when I tried to get it programmed it didn't work. They said I might need to replace the antenna and ignition tumbler to match the new ECU? Is this true? Did I even have to replace the ECU in the first place? I am really lost and any help would be greatly appreciated.
Thanks
Old Feb 20, 2012 | 09:53 PM
lowlife9's Avatar
no the ecu reads the key changing the tumbler won't help.
Old Mar 21, 2012 | 12:43 PM
mr green's Avatar
if you get a new ecu u need the keys that go with it but your ecu might be ok it could be the wire harness. there could be a bad wire or connection between the hook up for the code reader and the ecu
Old Apr 11, 2013 | 01:22 PM
Mallik Subhan's Avatar
I owned 2001 honda civic lx recently.I got ignition problem,we made computer check up.found that ECU was bad.so if i get second hand ecu what things i have to do,i mean
i can start with old key.
Old Apr 11, 2013 | 04:08 PM
lowlife9's Avatar
if you get a new ecu you have to have your keys re-programed at a honda dealer or it won't start.
2Hondas
Nov 8, 2020 10:15 PM
stonecold
Aug 17, 2012 02:07 PM
popriv
Jun 15, 2011 12:17 PM
Bill Cory
Oct 6, 2008 09:06 AM
mosco13
Jun 13, 2008 05:54 AM
