How difficult to replace sway bar link?
Old Jun 13, 2011 | 09:28 AM
popriv's Avatar
Default How difficult to replace sway bar link?
Just finished up with rotors and pads on the rear of my 98 EX Coupe and I noticed the sway bar has separated from the sway bar link on the passangers side. I can move the two parts together by hand ( I would have thought there would be more tension in the sway bar making it difficult to move? ) Anyway, the parts is about $21. It looks easy enough to replace? Is this a straight parts replacement or are there any adjustments needed?
Should I tackle this myself or should this be done by the shop?
No lift so I have to work on this on the ground.
Also, can I drive the car as is? (until fixed of course)
Thanks
Steve
Old Jun 14, 2011 | 02:03 PM
Easy job,I wouldn't drive it hanging down or anything,you can remove it until you have time to repair it,maybe repaint it while you have it off.
Old Jun 15, 2011 | 12:17 PM
91haydenSI's Avatar
It's not too bad of a fix. Worst part is when you remove the sway bar you will notice the front tires move back about an inch making it a little difficult to line to bolts back up but a 2x4 wrapped in cloth always does the trick for me.
2Hondas
Nov 8, 2020 10:15 PM
McD
Jun 2, 2015 11:47 AM
nero
Aug 7, 2009 05:53 AM
Bill Cory
Oct 6, 2008 09:06 AM
ASU97
Jul 13, 2007 06:20 AM
