2005 civic VTEC rumble
Old May 13, 2009 | 01:01 AM
Lynds's Avatar
Default 2005 civic VTEC rumble
HI, when i go to start up my 2005 honda civic v tec engine if it has been sitting for more then like 8 hrs it makes a mild rumble sounds right when i turn on the ignition. It ONLY does it if the car has been sitting for a bit and makes no other noises while running. If i stop the car turn it off and turn it on again it doesn't make the sound. What is this? The sound is coming from the engine compartment, i think HELP!
Old May 14, 2009 | 05:06 PM
welcome to the forum, before you start your car next time after 8 hrs, have someone else start your car for you and go under the hood and listen to see approx where this sound is coming from, it could be low power steering fluid, the a/c compressor if this is on all the time, it might be the water pump, it could be low oil or thick oil not getting up to the top side of your engine, sorry could be a lot of things. Also could be a cracked exhaust manifold, and closes up after warm up. check the exhaust manifold first.
snotsmear
May 16, 2017 01:25 PM
Nic Graham
Aug 11, 2014 02:40 AM
dlb958
Apr 17, 2011 12:02 PM
turbohonda
Jul 24, 2010 10:56 PM
Drissle
Oct 29, 2008 09:18 AM
