2005 honda civic 1.7lt v-tech help
Old Apr 11, 2013 | 11:00 AM
#1moe's Avatar
Default 2005 honda civic 1.7lt v-tech help
2005 honda civic 1.7lt v-tech had a blown head gasket.removed the head and sent to machine shop installed the head and ran for 30 secs miss firing on #4 cyl no compression removed cyl head again and had machine shop replace 1 bent exhaust valve on #4 cyl which was the 2nd exhast valve from the rear of head .now the car runs fine but getting code p6426 replace the v-tech oil pressure switch still getting same codecould the actuator have been damaged with the bent valve any ideas ?
Old Apr 13, 2013 | 07:57 AM
accord_99's Avatar
Have you tried restarting the computer maybe if you restart it, the code will go away.
Old Apr 13, 2013 | 10:24 AM
#1moe's Avatar
have tried resetting the ecm have also tried a new v-teck solenoid still same code but the discription on the scanner for p2646 is not low voltage for the v-tech oil presssure switch but reads rocker arm actuator bank 1 or shut off,any ideas
Old Apr 13, 2013 | 11:27 AM
accord_99's Avatar
Have you checked your oil level maybe its low that sometimes causes the code to come on but your best bet would be replacing it
Old Apr 15, 2013 | 09:55 AM
#1moe's Avatar
going to replace oil this morning and reset ecm
Old Apr 15, 2013 | 01:15 PM
#1moe's Avatar
Solved
Old Apr 16, 2013 | 11:52 PM
accord_99's Avatar
What was the problem bro
Old Apr 17, 2013 | 09:56 AM
#1moe's Avatar
loose bolt at rear of rocker arm assembly
Old Apr 17, 2013 | 04:07 PM
accord_99's Avatar
Smile
Well at least it wasn't anything expensive but that's good that you fixed it man
Dlygamtrupfar
Jan 22, 2010 01:42 AM
GStevison
Sep 1, 2009 06:32 AM
poetntheprocess
Sep 6, 2008 07:51 PM
lethallykreated1
Nov 26, 2007 10:02 AM
drunkenmunkey
Jun 5, 2007 11:10 AM
