2009 CRV bypass inlet hose
Old Apr 18, 2019 | 06:19 PM
challenger12589's Avatar
Default 2009 CRV bypass inlet hose
I'm working on a 2009 CRV 2.4 the bypass inlet hose is leaking at the thermostat housing. Is there a easy way to replace it? Does the exhaust and intake need to come off.....need help please
Old Apr 18, 2019 | 10:13 PM
In the Haynes manual, it says when working on a CRV, access is from the underside of the engine compartment.
Jack up the vehicle, put jack stands under for safety, drain radiator coolant, follow lower radiator hose to engine, locate thermostat,
Disconnect clamps, remove hoses, (for thermostat replacement) remove two bolts holding housing
Good luck
vern1
Oct 30, 2018 04:08 PM
ironknight
Jul 22, 2018 04:12 AM
ZillaG
Feb 24, 2015 10:45 AM
sloweddi
Feb 3, 2015 07:47 PM
ajaybali
Apr 26, 2010 02:19 PM
