2014 Accord Oil Leak
Old Jun 12, 2018 | 08:20 PM
Mihondaa's Avatar
Default 2014 Accord Oil Leak
My front grill has oil on it and it looks like the fan might be spraying it there but I am not sure. Any advice would be appreciated to where the oil might be coming from.
Old Jun 12, 2018 | 08:27 PM
welcome to the forum. the oil spots on your front grill appear to be from a vehicle you followed. the fan brings air from the front to the back, does not blow out front of the grill. also if there was a leak you would see it dripping under your engine compartment. give the car a good bath and it should look good again.
Old Jun 13, 2018 | 05:33 AM
Mihondaa's Avatar
Default Oil spill under car
This isn’t the first time it happened and it’s getting worse.
Old Jun 14, 2018 | 02:16 AM
if it is coming from your car, only other thing i have seen is the radiator anti freeze is shooting out front from a leaking radiator, or lubricant from the a/c line is leaking.
Stevebow
Jan 10, 2023 10:54 AM
sclieu
Sep 30, 2019 10:11 PM
skunk_ape311
May 19, 2019 06:59 PM
kbrook1218
May 27, 2013 05:21 PM
clarkkentski
Aug 26, 2008 03:13 AM
