3.5l Vtec Oil control valve assembly
Old Sep 4, 2021 | 04:01 PM
Eljeef's Avatar
Default 3.5l Vtec Oil control valve assembly
Hi. I have an 06 Ridgeline with the 3.5l. I am trying to cure some oil leaks. I removed my valve assembly with the oil filter hanging off of it. I turned it over in my hand to unplug the pressure switch and heard something with some weight to it land in my oil drain tub directly below. I searched in the pan (which had about 5 oz of oil in it) and pulled out a small ram/dumbbell looking piece. That's all there was. In the schematic I found online, it looks like a spring goes in before that piston does. I don't seem to have one and because I wasn't looking when things fell out I don't know if the truck did have one. I have searched for the spring 3 times to no avail. Please help. Is there supposed to be a spring?
Jeremy Thompson
Aug 23, 2021 07:53 AM
hondaguy1
Feb 1, 2017 06:11 AM
mrcoolhead
Jan 31, 2013 07:38 PM
desione08
Sep 20, 2009 11:13 AM
dahuckman15
May 30, 2008 03:25 AM
