86 accord idle problem and hot water pump
Old 07-23-2007 | 11:59 PM
86_accord2.0's Avatar
Default 86 accord idle problem and hot water pump
hey guys i just got an 86 accord about a month ago it was running fine and then about a week ago it started to sqeal and the alternator was hot and so was the water pump pulley so i replace the water pump and alternator along with the belt any tips or ideas. fyi it also started to smoke!(the belt or something)
[/align]
Old 07-29-2007 | 10:44 PM
Dongss's Avatar
Default RE: 86 accord idle problem and hot water pump
when the car cooled down, does it still start?
Dongss
Old 07-30-2007 | 08:25 PM
[blockquote]yeah it does i think i got the idle down and i think the belt was on too tight so i loosened it up and now i think the battery isnt charging because my interior lights dim when i turn an my signals and head light mind u even with the vehicle running[/blockquote]
Old 08-01-2007 | 06:50 PM
Dongss's Avatar
Sounds like your alternator or battery is still bad. Make sure the alternator belt is tight, it should deflect with finger pressure around 1/4 inch at the longest length.
Have you used a voltmeter to test the battery? Better yet go to your local pepboys or auto zone or sears auto center and have them load test your battery and alternator. This is usually a free service. Your battery should be around 12.6V with the car off, and at least 13V with the car running.
Maybe it's just a simple new battery that you need.
Let us know what you find.
Dongss
honda al
03-13-2014 12:49 AM
chrisn82
04-22-2009 05:31 AM
sandyg645
10-20-2008 07:19 AM
altownsend
07-29-2007 10:14 PM
fondario
11-30-2006 06:51 PM
Quick Reply: 86 accord idle problem and hot water pump
