88 Prelude idle problem
Old Dec 19, 2008 | 03:13 PM
skorpion725's Avatar
Default 88 Prelude idle problem
Hey I have an 88 Honda Prelude 2.0si fuel injected and DOHC. The engine idle revs up and down constantly. I have thoroughly inspected all the vacuum lines for leaks and nothing. Any suggestions as to what else it could be?
Old Dec 19, 2008 | 10:58 PM
asltrucker's Avatar
Default RE: 88 Prelude idle problem
I had this problem with 89 Honda CRX HF. Dealer checked it is the alt. Because the PCM depends on a clean DC voltage and it is likely that your alt's diodes getting tired. The PCM is confusing with dirty DC current (or AC current). Suggest go to dealer and hook up with their scanner. If they say it is ALT, then you fix it yourself. Good luck
bcole6
Apr 30, 2013 09:30 AM
benjammin
Sep 1, 2009 07:09 AM
zem
Jul 11, 2009 03:58 AM
skorpion725
Jan 13, 2009 03:13 AM
BigDan
Jul 25, 2006 12:22 AM
