'93 Accord SE Speedometer Problem
Old Dec 10, 2010 | 05:08 PM
rabbithutch's Avatar
Default '93 Accord SE Speedometer Problem
Recently the speedometer on our old Accord starting registering about 15-20 mph lower than actual speed. I've looked at a parts list and found a speed sensor. Is that the likely cause?
The last time I dealt with a speed sensor problem was on a 1950 Ford Custom about 50 years ago. Back then there was a little plastic gear that went into the tranny. Different number of teeth would cause the speedo needle to show faster or slower. I expect things are quite different now.
Is the speed sensor replacement something and old grey-haired geezer can get to and change? From the parts list, I couldn't tell where the assembly is located. Can anyone point me to a good diagram that will show where to find the unit that contains the speed sensor?
TIA
Old Dec 14, 2010 | 08:09 AM
Welcome to the forum, I would suggest talking to a transmission tech they can most likely help with the speedo problem,coming from another geezer sir.
Old Dec 15, 2010 | 12:15 AM
try the speed sensor, not hard to change. If you go to hondaautomotiveparts.com and or autozone.com and go to repairs it will a pic of where andhow to change.
Old Dec 16, 2010 | 02:42 PM
NothingElseMatters's Avatar
Originally Posted by acmech52
try the speed sensor, not hard to change. If you go to hondaautomotiveparts.com and or autozone.com hid light kits and go to repairs it will a pic of where andhow to change.
I didnt even know their site had more then just the option to purchase from them, haha. Thanks for the info though.
lyndze821
Aug 7, 2009 03:03 AM
seebi_31
Feb 9, 2009 08:19 PM
mowntnbkr
Oct 23, 2008 09:17 PM
pandong
Dec 9, 2007 05:30 PM
pandong
Sep 20, 2007 10:06 PM
