O2 sensor problem
Old Dec 16, 2010 | 10:39 PM
Denning's Avatar
Default O2 sensor problem
I have a 99 accord that needs to pass smog soon but the check engine light is on. I ran the code check on it O2 bank 1 sensor 1 heater circuit came up. I replaced it twice and the code keeps coming back, i even replaced the second sensor I need help ! Any one have this happen to them ?
Old Dec 17, 2010 | 03:36 AM
welcome to the forum. If you are using an after market sensor, it can happen that the code will return. if you replaced with a factory sensor it should not come back. Yes the factory sensor and the after market sensor is made by the same co.
Old Dec 17, 2010 | 09:49 AM
Denning's Avatar
The brand is Bosch is there no way to get rid of the code other than swapping it for a oem part ?
Old Dec 18, 2010 | 02:46 AM
Not that I know of at this time.
Bill
Mar 1, 2008 08:48 AM
chuck norris hx
Nov 30, 2006 10:24 AM
redintex
Nov 27, 2006 08:21 AM
ed1le
Jul 17, 2006 02:00 PM
1998HondaCivic
Jan 20, 2006 02:13 AM
