94 Honda del sol Dash Lights
The cluster Dash Lights are not working. The heater, Radio, and gear selector lights work. I can dim all dash lights that work with the dimmer ****. I got power at the fuse box. I took the cluster out and no power at the plug and i check all the bulbs. All other lights on that circuit work.Please Help!!!!
1994 Honda Del Sol Si
RE: 94 Honda del sol Dash Lights
welcome to the forum. power at the fuse box, fuse is good, no power at the plug, power wire from the fuse box to the plug has a short, break, or plug pin has backed out. if there is a y split to allow 1or morepower wire to split to several light units, then there also can be a failure at the y split.
JennyBoo311
03-04-2021 08:06 PM
cookiekare
09-24-2019 12:27 AM
mike0094
06-01-2009 09:05 PM
