94 Honda del sol Dash Lights
Old Dec 3, 2008 | 12:04 PM
SIRDUKE's Avatar
Default 94 Honda del sol Dash Lights
The cluster Dash Lights are not working. The heater, Radio, and gear selector lights work. I can dim all dash lights that work with the dimmer ****. I got power at the fuse box. I took the cluster out and no power at the plug and i check all the bulbs. All other lights on that circuit work.Please Help!!!!
1994 Honda Del Sol Si
Old Dec 4, 2008 | 07:14 AM
Default RE: 94 Honda del sol Dash Lights
welcome to the forum. power at the fuse box, fuse is good, no power at the plug, power wire from the fuse box to the plug has a short, break, or plug pin has backed out. if there is a y split to allow 1or morepower wire to split to several light units, then there also can be a failure at the y split.
Old Dec 4, 2008 | 08:22 AM
SIRDUKE's Avatar
Thanks for having me here acmech52.. I thought there might be a relay or something inline to the cluster. I guess i can run a wire to the plug. Thanks you
JennyBoo311
Mar 4, 2021 07:06 PM
cookiekare
Sep 23, 2019 11:27 PM
tallbright
Oct 31, 2012 09:04 AM
mike0094
Jun 1, 2009 08:05 PM
marky4
Oct 13, 2006 08:24 PM
