95 civic ex. no power to half of fuse panel
Old Dec 13, 2009 | 09:03 PM
1lowcivic's Avatar
Default 95 civic ex. no power to half of fuse panel
ok the other day i was driving my 95 honda civic ex 1.6l vtec down the road and my headlights started dimming and then the radio shut off and the speedometer and rpm gauge shut off also. so i pulled over and let it idle and checked the battery terminals and they were tight and not corroded. then the car just died. pulled the alt. off had it checked it was bad. bought a new one put it on. charged the battery up on a charger. now the car is reving up and down and when the rev drops the battery light comes on and i checked the #15 fuse and changed it n its good. and i tested the fuses in the car. and the driverside of the panel doesnt have power but the passenger side of it does.(fuse panel in car)all the fuses are good under the hood. any body have any ideas?
Old Dec 16, 2009 | 03:28 AM
welcome to the forum. Check all your connectors to besure they are clean and secured tight. not just view them. if you have firewall connectors check those also.
needhelp718
Nov 19, 2013 08:02 PM
Kevin Pang
Nov 22, 2011 12:52 PM
94cx
Mar 16, 2010 10:51 AM
JayJay
Aug 20, 2007 11:46 AM
BobSed
Jan 3, 2007 06:31 PM
