99 Odyssey J series timing belt problem
Old Feb 20, 2014 | 10:13 AM
prisbylla's Avatar
Default 99 Odyssey J series timing belt problem
Hi all-
First post, hoping I can get some advice. I am putting things together after a head gasket job on my van and have encountered a problem. I am trying to put the camshaft sprockets at TDC so I can install the timing belt. Unfortunately, there is a problem with the rear sprocket. There are 3 spots in the rotation of the cam 120 degrees apart where all the valves are closed and thus the camshaft will come to rest. Problem is that the timing marks don't line up in any of these 3 positions, they are at least 1/6 of a rotation off. This is the long line on the rear camshaft sprocket and the corresponding mark on the back timing belt cover. Any ideas?
Mike
sjv
May 29, 2018 06:02 PM
nomrod
Sep 8, 2014 07:44 PM
jstagn
Aug 10, 2011 01:53 PM
kayslay
Mar 29, 2009 12:26 AM
