Alternator exchange
Old Jan 22, 2007 | 09:17 PM
illwilll24's Avatar
Default Alternator exchange
I have a 94 honda accord and need an alternator swap but not quiite sure how to get this done...ive been told its fairly simple. My air conditioning is weak, my lights dim when my sub hits and my sub clips at high levels of volume, so i think its the alternator... someone help me out with this please.
Old Jan 23, 2007 | 01:24 AM
4doorcivic9's Avatar
Default RE: Alternator exchange
ORIGINAL: illwilll24
well just before you actually go get a new alternator try the free stuff 1st before you go blow your money on one. Go take it to a local gayzone or O'silly's or w/e you have around their and get your battery tested! to see if it holds charge..they usually do it for free. Also check ur neg. and pos. on your battery to see if their loose or tight. just a few things you can check before you actually get a new alternator b/c it might not be that.
Old Jan 24, 2007 | 11:48 PM
illwilll24's Avatar
I have to bran new ultima batteries, the battery in the back is connected to my system and ascts as a cap... my lights STILL dim. i checked all the connections, i have a 97 accord in my backyard using for parts...just wanted to know the specs on taking it out......
Old Jun 21, 2007 | 06:43 AM
mike95691's Avatar
you could buy an alternator @ebay for $180 that has 135 amps that should fix the power you need.
Old Jun 23, 2007 | 01:54 AM
golfer's Avatar
I suspect you mean you have two brand new ultima batteries... and the one in the back acts like a battery not a capacitor. You might even try a battery isolator for the second battery it will also control the charge on that one when it only needs it.
forevermemorable
Aug 17, 2013 02:25 PM
SCCinc
Oct 8, 2007 03:53 PM
Rob
Jan 9, 2007 02:17 PM
Camel3g GT
Dec 31, 2006 03:33 PM
Gardensnake
Nov 19, 2006 02:22 PM
