bleed the brakes?
Yes you need to bleed the brakes but why is it(fluid) gone? Leaky lines, leaky master cylinder? Something is causing it to run out of fluid. Check that first. Then
Once that is fixed, if you dont know how to bleed the brakes, its very important to have someone who knows how to do it. Or you ll have air in the lines and you ll have a serious accident. Just a heads up and my 2 cents.
