Brake Fluid Type
Old Nov 21, 2019 | 08:13 PM
cueball21's Avatar
Member
Default Brake Fluid Type
I'm about to replace the brake fluid in my '93 Accord. The manual says to use either DOT 3 orOTot 4 - to look at the master cylinder cap to determine which. Looking at the cap shows both DOT 3 and DOT 4 are on it. I have no idea which fluid was used in the system originally. I'm the second owner and the car has ~205k miles.
If I use DOT 4 and the OEM was DOT 3 will it cause any harm? Which type fluid should I use, and why?
TIA
Old Nov 22, 2019 | 10:23 PM
Dot 3 and Dot 4 are very compatible and almost only differ by the operating temperature range
The Dot 4 having a higher temperature range.
Old Nov 22, 2019 | 11:56 PM
cueball21's Avatar
Member
Thanks!
Old Nov 23, 2019 | 09:26 PM
dont worry,they both will work fine.
papasloane
May 14, 2023 07:22 PM
Joel33333
May 11, 2020 08:11 PM
arthondal
Mar 6, 2014 06:37 AM
stook00
Sep 16, 2011 08:52 AM
03 civic
Jan 3, 2007 07:31 PM
