can' believe this happened at dealer.
Old Jan 18, 2011 | 06:38 PM
garyk10's Avatar
Default can' believe this happened at dealer.
My girlfriend took her Honda Odyssey Van for a oil change and was told that the repair plug on oil pan was shot and she needed a new oil pan. They did the work at cost of $370. She drove it home and did not drive it till the next day. After 20 min of driving the engine oil light came on and the engine started to make noise. She parked it and called dealer the next day because it was Sunday. After they test drove it they agreed about the noise and after checking it out stated that a piece from the repair plug lodged in the oil pump and said she needed a new engine. It is absolutely ridiculous to say it was not the dealers fault. I believe they never checked the oil pump screen and are now saying they did nothing wrong. Need to hear from anyone about her problem. Thanks
Old Jan 19, 2011 | 09:11 AM
Welcome to the forum,This is what I would do,Talk to the service Mgr. then Gen Mgr. at the dealership and if no resolution then call and file a complaint with The BBB where you live and then check the back of your owners manuel for a number for Honda USA they may be able to help. Good luck,Bobby
Old Jan 19, 2011 | 02:15 PM
garyk10's Avatar
Default Thanks.
Thanks Bobby. have done all that and have meeting with Honda NA Zone rep. Its consumed me. Not goin down without a fight. They screwed up and thats it. Gary
Old Jan 20, 2011 | 07:42 AM
Gary,I feel your pain buddy,you went through the right channels and something should be resolved by this, Good luck,Bobby
Old Jan 24, 2011 | 03:49 PM
garyk10's Avatar
Default Results from meeting with Honda zone rep.
Thanks for reply. Well just had meeting with zone rep and he is basically collecting a check. Would not get involved. The service manager stated that it is not in there job procedures to check the screen on the sump. The piece that he presented was the butterfly from the heli coil that he stated blocked the oil flow to the oil pump. Again he stated that they don't have to check screen. My girlfriend is devastated. She still owes for van. Contacted Honda NA and they are passing it on to regional manager. Don't expect much. Waitin for lawyer to call and filed complaint with Attorney General. I will not accept their answer. Why would'nt you check that screen. Anyone else that reads this post tell me why you don't check that screen. Thanks.
Old Jan 25, 2011 | 09:15 AM
Maybe it needs to be in their job procedure,just common since. Hope it turns out good for ya.I still can't believe they charged $370 to instal a pan.
Old Jan 25, 2011 | 09:08 PM
garyk10's Avatar
New info. Her receipt for the oil change prior to the oil pan placement shows that they swapped out the heli coil with a Honda Accord 14mm oil plug and washer. They let that piece from heli coil stay in pan and next oil change told her she needed a new oil pan. Why use a plug for a Honda Accord on a Honda Odyssey Van and also not fish out broken piece that caused all the problems. Again we have receipt showing this.
ohfourciviclx
Jan 11, 2015 06:50 PM
Hal
Jan 3, 2009 04:26 PM
radiolinija
Nov 18, 2008 12:09 AM
akamina 2005
Oct 31, 2008 04:30 AM
BluEkSleeper
Sep 29, 2006 12:48 PM
