Car Overheating with thermostat but running fine without a thermostat
Old Feb 26, 2012 | 06:17 PM
Oscar Ponce's Avatar
Default Car Overheating with thermostat but running fine without a thermostat
Turns out it was the thermostat. I drove it without the thermostat for about half a day and the car never overheating or spilled coolant from the radiator cap like it did before. Once I put a new thermostat in it went back to overheating and spilling all my coolant from the radiator cap. I ended up taking the thermostat out again and the car runs fine again. I know that I shouldn't drive it without the thermostat but I don't know how to fix this problem. Any suggestions?
Old Feb 28, 2012 | 02:40 PM
It's not opening up.
Old Feb 29, 2012 | 02:27 AM
Possible top of radiator is filled with corrossion.
Old Mar 2, 2012 | 04:15 PM
wayne0's Avatar
Member
I had the same problem. Replaced the radiator. Problem gone.
Old Oct 28, 2012 | 09:54 PM
Dustyb's Avatar
Had a car a while ago that the head gasket was leaking compression into coolant and the air would gather at thermostat and thermostat doesn't get hot enough to open with air around it.
Old Jan 16, 2013 | 08:21 AM
You maybe putting the thermostat in backwards also.
techman41973
Aug 11, 2015 04:48 PM
rbbarth55
Sep 26, 2011 11:55 AM
pyrodork
Sep 6, 2010 02:07 PM
thedaveman89
Nov 24, 2008 09:32 PM
shad9876
Sep 3, 2008 12:57 PM
