Check Engine Light P0506
Old Apr 27, 2009 | 01:02 PM
willieb's Avatar
Default Check Engine Light P0506
I just had my oil changed. When I started the car, my check engine light came on. I went straight to Autozone, and they pulled up P0506 code, Idle control system RPM lower then expected.
Does anyone has any idea what this might be, or how to get it fixed?
Thanks
Old Apr 29, 2009 | 04:12 AM
idle needs to be adjusted higher, or the idle cntrol valve needs to be cleaned. did the check engine light come back on after reading the code and resetting.
Old Apr 29, 2009 | 08:49 AM
willieb's Avatar
autozone did not reset the code, but after few hours it went away. then a day later it came back on. There really isnt any rpm issues, when i turn ac it drops a bit, but i think thats normal
Old Apr 30, 2009 | 03:01 AM
yes normal on a/c. sensor may be going bad to cause the light to go on and off.
Old May 1, 2009 | 10:35 AM
willieb's Avatar
do you know what sensor would that be?
Old May 2, 2009 | 04:50 AM
idle air intake air temp sensor along side of the throttle body. to be sure check in
hondaautomotiveparts.com ( majestic honda site. ) intake & manifold try cleaning it first.
fyah17
Dec 22, 2012 03:03 PM
samuel_gatech
Nov 4, 2009 04:46 AM
silverbullet
Feb 19, 2007 08:26 PM
cpatd
Nov 13, 2006 02:03 PM
whermanov
Sep 23, 2006 04:16 PM
